Car eving to 6800, is this safe???
Old Jan 22, 2003 | 05:07 PM
BOWTYDE's Avatar
I'm hoping it is. I got it reprogremed from PCMforless and put a new cam and springs in it, but I still have the stock rockers. Is this safe for it to rev that high?
Old Jan 22, 2003 | 05:16 PM
95CamaroZ-28's Avatar
You might be able to get by with it for a little while. Personally, I wouldn't do it with stock bearings. What kind of oil pressure do you have? Did you have your heads ported to go with the cam? I'm assuming it's a pretty good size cam since you're wanting to rev it that high.
Old Jan 22, 2003 | 05:25 PM
White_94_TA's Avatar
I know lots of LT1 guys who rev to 6800 with Upgraded springs and 1.6 Rockers but not with 1.5. Hmm
Old Jan 22, 2003 | 05:41 PM
BOWTYDE's Avatar
My thoughts exactly.
Old Jan 22, 2003 | 05:46 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
rpm's... Ruin Peoples Motors... i would check for leaks and knocks EVERYWHERE and often...
Old Jan 22, 2003 | 06:32 PM
LT1ponykilla's Avatar
I have the same program for my car, but I dont have an aftermarket cam yet! I have heard that there is no need to shift at 6600rpm's or higher because your power starts to fall off way before that.
Old Jan 22, 2003 | 07:04 PM
BOWTYDE's Avatar
That is what I was thinking aswell. I'm getting it Dynoed soon so I can see where that drop off is.
Old Jan 22, 2003 | 07:16 PM
lt1camaroman93's Avatar
It depends on the cam grind when the power starts to fall off.. My old lunait fell off around 6800-6900.
Old Jan 22, 2003 | 08:42 PM
OneFlyn95z28's Avatar
http://groups.msn.com/WashingtonFBod...to&PhotoID=439
Make sure you have the right valve train and hold on!
I must admit I have only been doing this for three years now
Old Jan 22, 2003 | 09:26 PM
jcolez28's Avatar
To rev that high you should consider hardened push rods( or crome moly) and roller rockers.
Old Jan 23, 2003 | 06:15 PM
WP's Avatar
WP
On the dyno my 306cammed car(w/lt4 heads)made peak hp @ 6300rpm!,shifts out of 1st and 2nd at 6400rpm,no reason to go any higher,sooner or later something is going to give going that high on rpm!
Old Jan 23, 2003 | 06:22 PM
LT1 with Hotcam kit, Gold Race rockers, Hooker LT's, Y pipe and Borla.. . Power peaked at 6500rpm and held till the 6800rev limiter.
Old Jan 23, 2003 | 06:43 PM
WP's Avatar
WP
A hot cam car peaking at 6500rpm? are you sure?!!!!
Old Jan 23, 2003 | 06:46 PM
Look for Yourself
http://ken.lowrance.com/dynosheetsmall.jpg
Feffman
Oct 9, 2015 05:42 AM
skittlez87
Dec 29, 2014 03:23 PM
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
bowtiepwr
Aug 7, 2002 08:02 PM
