car dosen't start after RR install
Old Jan 31, 2004 | 09:01 AM
94YellowTAGT's Avatar
At first the car didn't even try to fire but this morning it backfired out the exhaust really loud and still doesn't start. I checked the plugs and wires. what else could be the cause.
Old Jan 31, 2004 | 09:05 AM
Dave89IROC's Avatar
you changed the rocker arms?
if everything else is hooked up, the rockers are too tight(or really loose)
Old Jan 31, 2004 | 09:12 AM
I put crane gold 1.6 SA in last night. I have read numours post on how to install them and i think i did that right, but i guess not since the car doesn't start. i thought that it would atleast stubble a little bit and try to start even if the rockers are set wrong
Old Jan 31, 2004 | 09:38 AM
joeSS97's Avatar
How did you adjust them?That is the problem,no doubt.
Old Jan 31, 2004 | 09:41 AM
Smokn '94 Z's Avatar
Lightbulb
It sounds like you set the valve lash on the wrong stroke. I did this my first time & the engine just spun.... with a little backfire & raw gassy smell. I found out I set the Valve Lash off say 180 degrees.. Find TDC on the #1 again and make sure you are actually on the right firing sequence & then re-set the lash.. That is what you problem sounds like to me.
Noenav
Mar 1, 2019 07:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
Snake Slayer
Jul 29, 2002 12:39 PM
