Car dont start
Old Feb 18, 2008 | 04:07 PM
briggsbuilder's Avatar
Car dont start
I got a 96 transam 6 speed, with new coil, ignition module and opti.
This morning my car didnt want to start so i took of the starter thinking that was the problem. I was wrong the starter tested good and iam looking for edvice becuase i cant seem to figure it out.
All the connections are were they suppose to be and my battery has a full charger on it.
does any one have input on this? (this is my 5 time i regret buying a lt1)
Old Feb 18, 2008 | 04:45 PM
2000GTP's Avatar
Does the car crank at all or is it dead when you turn the key?
Old Feb 18, 2008 | 05:04 PM
dead when i turn the key. I just went to the store and bought a new ignition switch, does any body know were its located????
Old Feb 18, 2008 | 05:08 PM
ss.slp.ls1's Avatar
I believe the ignition switch is in the steering column.
Does the security light flash when you turn the key? Could be a vatts problem.
Old Feb 18, 2008 | 05:24 PM
camzaro28's Avatar
http://shbox.com/ignsw/ign_switch_repl.html
Took me about 3 hours taking my time with breaks in between. Not a hard task at all.
Old Feb 18, 2008 | 05:44 PM
Is there anything else i should look at besides ignition switch?????
how about the neutro safty switch.
On the showbox tech page its saysThe most noted and tell-tale symptom I have seen regarding switch failure is that the the gauge cluster goes dead. When it goes dead, the engine dies as well. This is because the ignition switch also powers a section of the pcm necessary for engine function, plus the fuel pump and some other things.)
My car has never cut off and i do have power to the cluster????
Old Feb 18, 2008 | 06:08 PM
Counted Out's Avatar
Didn't someone have a similar problem recently?
Turned out the water pump was leaking onto something. I don't quite remember.
Old Feb 18, 2008 | 06:25 PM
ss.slp.ls1's Avatar
That person had water leak onto their opti, but if that was the case, the car would still crank.
I'll ask again, does the security light flash?
Old Feb 18, 2008 | 06:53 PM
It lights up for like 3 seconds then it turns off.
Old Feb 20, 2008 | 03:16 PM
anyone else have any input????
Does anybody know were the nuetral saftey switch is located????
Old Feb 20, 2008 | 03:53 PM
BUBBA's Avatar
Never looked, but Neutral Safety switch should be connected to clutch pedal since you can't start it without the clutch being disengaged.
BTW: will it start with a push? Shouldn't take much in 2nd gear to get it started.
I know that you said that the battery has a full charge, but the very first thing I'd suspect would be a bad battery. I never assume that the battery is good, unless it is new and charged up.
Don't assume anything. JMHO
Old Feb 20, 2008 | 04:46 PM
yeah the battery has a full charge.
Old Feb 20, 2008 | 04:50 PM
BUBBA's Avatar
Will it start when pushed in 2nd gear?
Old Aug 18, 2011 | 08:04 PM
sherwinZ28's Avatar
Re: Car dont start
Hate to bring this thread from the dead but I have the exact same problem. Battery is good, new starter...old starter was still ok though. Car won't start...lights, radio, cluster works, security light turns off after 3 seconds like it should. I had to pop the clutch to bring it home so I know the motor is good. I just checked the clutch switch and I am getting 11.5 volts to the switch when I turn the ignition key to the start position. Anything else to check after that? Would the coil cause a no start. It seems like something from the ignition to the starter is not working. I think the ignition is good cause I get a signal to the clutch switch when I put it in the start position. I'm thinking the quickest fix would be wire up a push start straight to the starter...anyone know how to do this on our cars...what wire to tap into etc?
Edit: Checked all fuses under hood and in interior panel as well as the fuse block(?)(red cap under the hood) all looks good no blown fuses.
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
