Car Doesn't Work!!
Old Nov 23, 2005 | 05:43 PM
ChrisUlrich's Avatar
Car Doesn't Work!!
Car doesn't start at all... there is a heavy fuel aroma during cranking. We unhooked the coil wire from the opti. There is spark at the coil.
I'm about to get back outside to disconnect one of the spark plug wires and hold a screwdriver next to it to see if the Opti is giving the wires juice.
The fuses in for the "Ignition" and "Injectors" are fine... but I did notice that the "Ignition" fuse was labeled "20?" I thought it was supposed to be 10 amps?
Any suggestions on what it could be?
Old Nov 23, 2005 | 05:57 PM
FastZinTennessee's Avatar
Re: Car Doesn't Work!!
If there's a heavy fuel aroma I'd be really careful about holding a screwdriver near the opti and checking for spark. Wait until the area is cleared out. If the fuel smell is that strong it might be flooded.
Disconnect the PCM fuse (so the injectors won't spray), crank it over a few times. Then check for spark.
Old Nov 23, 2005 | 06:10 PM
I'm going to check it in like 20 minutes or so... so the fumes will be gone... any suggestions though?
Old Nov 23, 2005 | 07:14 PM
OBE1 95Z28's Avatar
Hold the gas pedal to the floor and try cranking; this will signal the PCM to delivery less fuel (flood start mode).
Old Nov 24, 2005 | 09:52 AM
NVetro's Avatar
status?
Old Nov 25, 2005 | 10:48 AM
No one?
Old Nov 25, 2005 | 11:01 AM
Gripenfelter's Avatar
Probably the opti.
Old Nov 25, 2005 | 03:06 PM
Originally Posted by Gripenfelter
Probably the opti.
I think you're right... I found out there is a leak from the Water Pump... the guy didn't put any sealant on the pump threads... UGH!!
Red97LT1
9
Dec 17, 2014 06:13 PM
USAirman93
Nov 24, 2014 03:37 PM
mjcent922
Jul 27, 2002 12:42 PM
Paulberg
Jul 26, 2002 11:35 AM
Snake Slayer
Jul 26, 2002 06:14 AM
