Car dies when warm
Old Apr 29, 2007 | 06:11 PM
Fullagar's Avatar
Car dies when warm
OK, I did do a search but didnt see anything that pertains to this problem
The car is a 1993 Formula, we just changed the cap and rotor because it was missing something terrible, and this did fix the missing. The problem now is that after about 10-15 minutes of driving (just getting to operating temp) the car wil die and not start again till its cooled off. We have changed the coil and the ignition module and the fuel filter...but nothing has fixed it. Currently I am thinking it has something to do with fuel because it doesn't throw a code when it dies. The car seems to have good pressure at the fuel rails, but I have not put a fuel pressure gage on it to see if it is the 42 PSI its suppossed to be. Any ideas?
Thanks,
Fullagar
Old Apr 29, 2007 | 07:43 PM
Guest47904's Avatar
Guest
It's unlikely you have a fuel pump issue since they usually eventually show a problem at restart. Though it wouldn't hurt to check pressure.
Next time it dies, pull a plug wire and plug another known good plug on it and see if it has spark.
Old Apr 29, 2007 | 10:45 PM
T/A-Bob's Avatar
Coolant temp sensor? (the one in the front of the water pump)
bfmv13trivium
Jan 14, 2015 09:57 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
