Car dies once given more than 50% throttle
Old Jul 5, 2004 | 02:29 AM
Robert_K's Avatar
I am having a prblem with my car dieing if I puch it past 2500 rpms. It just starts popping than the rpms drop to zero and it shuts off. I can drive the car around on 1500 rpms with no problems for a short time but once the car starts to heat up a little ( 30 mins or so) it will start popping and dies at even 1500 rpms. I put in a new opti today but still have the problem, a month ago I put in new plugs and a coil ( but did'nt have this problem back then). Also about 2 weeks ago I replaced my 22lb injectors with 24lb injectors from the 94+ model LT1s. I was also told that this can be a tranny problem, any help would be greatly appreciated.
Old Jul 5, 2004 | 03:40 PM
TobyZ28's Avatar
Sounds like your car is running ridiculously rich. Probably the injectors...
Old Jul 5, 2004 | 07:47 PM
Robert_K's Avatar
Thats what I thought too, at first! The car smells like gas when its running and when it dies it smells even more like gas. Ever since I bought the 24lb injectors (used) the problem started (about a week later). My stock 22s were leaking and caused the car to have hard starts, the 24s start up great but have bad air/fuel ratio mixes.
Old Jul 5, 2004 | 08:06 PM
Fastbird93's Avatar
Get a tune for the 24# injectors. Talk to chips@pcmforless.com. He'll get you hooked up.
FWIW, on a 93, 24# injectors won't have too much bearing on the car, seeing as how the 22# stock injectors are being run at approximatly 23.7-9 anyway.
What's your fuel pressure doing during this stalling issue??? You can hook up a pressure gauge and stick it up against the windshield and drive it around.
Old Jul 5, 2004 | 10:06 PM
IllusionalTA's Avatar
Fuel pump? Map sensor? etc...
Old Jul 5, 2004 | 10:13 PM
sluggoz28's Avatar
help
sounds like your catalytic converter is pooched,you can tell right away by just driving the car up a hill....it should get worse....
...*bad cat*.good luck.
Old Jul 6, 2004 | 02:04 AM
Robert_K's Avatar
catalytic converter? I'll try it! I'm thinking of just taking it off and running straight pipes to the muffler. MAP sensor, what are the symptoms of a bad map sensor? I need to hook up a fuel pressure gauge but have just wasted all my money on the opti, cap & rotor, o2s, IAC, Balljoints and other parts. I'm going to prime the fuel system and check for leaks. About the fuel pump, if it was the pump, woul'nt I have hard starts? What are the symptoms of a bad fuel pump?
Old Jul 6, 2004 | 10:44 AM
TobyZ28's Avatar
Bad Fuel Pump -> Low fuel pressure, hard starts, consistant high rpm stumble (revs but feels like its hitting a wall and accellerates slowly above a certain rpm until it shifts)
Old Jul 6, 2004 | 01:42 PM
kmook's Avatar
Advanced Tech Moderator
I had a very similar problem. It was bad o2s.
Old Jul 6, 2004 | 07:04 PM
Robert_K's Avatar
I just put in o2s 2 weeks ago. I thought my o2 were bad but it made no difference in the performance of my car. Do you think I should pop in my old o2s and see if it fixes the problem? Before I had hard starts ( it ended up being the injectors), and changed the o2s, coil, and IAC with no difference. Do you think I some how clogged the new o2s with the bigger injectors in my car? Do you thinkn I clogged my catalytic converter? Toady I switched out my ols 22lb injectors but still had the same problems, so the bigger injectors cant be at fault.
Old Jul 6, 2004 | 07:23 PM
kmook's Avatar
I'm not saying it is your problem... but I had a similar problem and thought it couldnt be my O2s as they were like 1 month old, i put back the 90,000 mile originals and the problem went away
Old Jul 6, 2004 | 11:02 PM
Dave Feerst's Avatar
I've seen maby O2s broken from overtorqueing.
Mabye they werent 24s? are you sure they were the stock injectors?
Old Jul 7, 2004 | 04:00 AM
Robert_K's Avatar
Positive they were stock! I bought them from a board member who had it on his 95 Z. I'm going to switch out my old 02s and see what it does right after I replace my ICM. I was checking my ignition system when I found that the ICM was craked and was falling apart. I also spaced out the coil rack from the block and space the ICM and cooler away from the coil rack, it should help with heat. I know I did'nt break the o2s from over torquing, I probably did'nt torque them in hard enough which brings me to the thought of an exhaust leak, though I highly doubt something that small would cause car to shut off when I push the gas. I also seafoamed my car today and found that the problem stayed and realized that any time the car reaches 2500rpm or so it stumbles, misfires and shuts off. I did it at a stop while revving the motor.
Old Jul 8, 2004 | 07:46 PM
Robert_K's Avatar
Changed the ICM now it runs strong again. I have'nt punched it yet, but i'm confident it worked.
Old Jul 8, 2004 | 07:55 PM
bdc95ta's Avatar
after you punch it a couple of times let us know what's up.
-brandon
bfmv13trivium
Jan 14, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
