Car died need help!
Old Jun 15, 2005 | 05:40 PM
POSSESSEDZ's Avatar
Car died need help!
I was on the highway and my car lost all of its power would go above 1500 rpm's. So i pulled over and try to restart it whould kind of fire but it was just for a second. Need some help for the cause of this. Iam thinking optispark.
Old Jun 15, 2005 | 06:18 PM
LT1-Z's Avatar
Re: Car died need help!
I'd start checking every connection, sensor, wires, electronics and what not. Basically anything electrical for a start.
Old Jun 15, 2005 | 06:46 PM
POSSESSEDZ's Avatar
Just a couple of days before this happened my low coolant light came on but when i checked the level is was ok.
Old Jun 15, 2005 | 08:43 PM
white93lt1's Avatar
my car did the same thign and i changed my altenator and bam...problem solved.....could be that...that would be my guess so far
Old Jun 16, 2005 | 05:37 AM
slopokrodrigez's Avatar
The very first thing you do is push the schrader valve in on the fuel rail. If there is no fuel pressure there, there's your problem. If there is fuel pressure, hold it in till all pressure is relieved. Now cycle power with the engine off power on for 2 seconds and then off. Do this 4 or 5 times. Power off, and now push the schrader valve again. See if fuel pressure is back. If so, move on to spark. but chances are you will see no fuel pressure by the way of fuel squirting out the schrader valve. Be careful when you do this by the way. Could be voltage to the pump as in relay or wiring but chances are good the fuel pump went t!ts up.
Dave
Old Jun 16, 2005 | 12:33 PM
POSSESSEDZ's Avatar
Fuel pump was replaced last year, But i'll check the pressure anyway. Things have changed now the motor won't turn over it will just clicks. I went out today to start my back up car its doing the same thing. What the hell. Iam having a bad week. I have a new alternator in both cars.
Old Jun 16, 2005 | 12:47 PM
CobraEatr's Avatar
That sounds like the same problem I have about a month or two ago. I changed the ignition coil (about $15 at Autozone) and Wha-La. Car fired right up and has been fine ever since.
Old Jun 16, 2005 | 02:15 PM
POSSESSEDZ's Avatar
What can i do to check if the coil went bad
Clicking is a sign that you don't have enough current getting to the solenoid. Either battery is bad or weak or there is a bad connection somewhere between the battery and the starter. Don' forget the grounds too. Start by checking the battery connections for corrosion.
Old Jun 16, 2005 | 02:23 PM
POSSESSEDZ's Avatar
Battery is fully charged but my battery volt meter in the car goes in the middle of the red area when i try to start it.
Old Jun 17, 2005 | 06:57 PM
How do you know the battery is fully charged? How do you know the battery is good? Have you checked the wiring for bad contacts?
Old Jun 18, 2005 | 02:27 PM
POSSESSEDZ's Avatar
Battery was only 2 months old when i put a charger on it, It went to the fully charged indicator. Well i put in a new starter and now the motor cranks but it won't fire,I guess i'll go through all the wires and see if iam getting spark.
Old Jun 18, 2005 | 05:08 PM
96lt1Camaro's Avatar
Check the bolt on the back of the alternator. It should have no movement available. It should be nice and tight. If you can turn it either clockwise or counterclockwise then i think you need to change the whole alternator
Old Jun 20, 2005 | 10:15 PM
POSSESSEDZ's Avatar
Re: Car died need help! The results.
I got the call from the dealership and here'e the damage $697.00. Starter and coil fried. They said i must have had a voltage surge or short. I ask them if they found the cause and they have no idea. So i ask them if this will happen again and they couldn't give me an answer. We'll a least the car is running for now. Have this happen to anyone oon here? If so what was the problem.
Old Jun 21, 2005 | 12:26 AM
Gripenfelter's Avatar
Weird. I would have guessed the alternator crapped out.
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
