car died....help
Old Apr 2, 2005 | 08:25 AM
hawk232's Avatar
car died....help
ok, so last night i was driving, dropped it down a couple gears and jumped at my friend (prolly about 4k rpms) after i jumped, car died. fuel pump is priming, opti is getting power from coil, plugs are not getting power, is there anything besides the inside of the opti that could be responsable for this?
Old Apr 2, 2005 | 10:31 AM
Jasonz28camaro's Avatar
Re: car died....help
timing chain = broke
Old Apr 2, 2005 | 04:50 PM
hawk232's Avatar
so what could i do to find out what it is? considering that the coil is sending spark to the opti, but the spark somehow gets lost between the opti and the plug, wouldnt it almost have to be the opti? any help would be appreciated...
Old Apr 2, 2005 | 04:53 PM
CoUnTryMuZiCZ28's Avatar
Could be your ICM (Ignition Control Modual).. Or possibly your Coil. How old is it? Are you running an ignition system? It may have grounded out and shorted. Maybe your coil wire.. Anyhow, if you take the ICM to an auto parts store they can test it. That will eliminate one thing. Dont forget the dilectric grease for the back of it..
Oh.. and dont listen to him.
Old Apr 2, 2005 | 05:01 PM
hawk232's Avatar
correct me if im wrong, but if it was the icm or coil, or coil wire, i wouldnt be getting spark to the opti would i? i pulled the coil wire out at the opti end and grounded it, and it was sparking...
Old Apr 2, 2005 | 05:04 PM
Ahh.. you are correct.. answering like 50 threads at once i got confused.. Didnt even realize.. Sounds like the opti in that case.. Did you check ALL your plug wires? Might have blown a fuse.. Maybe the opti connector came loose..
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
