Car died again.... Fuel pressure now.. What to replace?
Old Aug 22, 2008 | 03:29 PM
94SLUG's Avatar
Angry Car died again.... Fuel pressure now.. What to replace?
I just put this pump in not but 2 weeks ago. Car was doing great until fuel pressure droped to 25-30psi. Key on only goes to 28... I can get the car started with starting flued only (I did this once just to see)..You think this is a bad pump, regulator, relay, maybe even filter? I also replaced injector seals...
Old Aug 22, 2008 | 04:05 PM
Granite00's Avatar
Sounds like maybe the hose inside the tank that connects the pump to the steel line might have a leak. Does the pressure drop right down after it builds pressure? It should hold for a few minutes before it drops.
Old Aug 22, 2008 | 04:26 PM
Connexion2005's Avatar
Pressure regulator could be going as well but normally that would allow for to much fuel pressure.
Old Aug 22, 2008 | 05:11 PM
Green96Z's Avatar
Replace the filter first. You should have replaced it when you replaced the pump. You could have an obstruction in the fuel line. The injectors would not affect fuel pressure, unless one is leaking. The relay is not at fault, because the pump is on, you just have low pressure.
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
