car died... again
Old Apr 6, 2006 | 08:21 PM
DavesLT1's Avatar
car died... again
I went to start my car yesterday and at first it cranked and fired up, then about 3 seconds later it died. not only the engine but the electrical system on the car was out for a few minutes then started working. after that the engine won't turn over, it will crank just fine so the battery is good, I put a fuel pressure gage to it and got 43 psi. so I'm left with no spark, but I just replaced the distributor and water pump in December. any ideas what else it could be?
Old Apr 6, 2006 | 09:28 PM
hotrod18_69's Avatar
Re: car died... again
Kinda sounds like the distributor again.. Did you get a GM replacement or one from like autozone??
Old Apr 7, 2006 | 10:31 AM
DavesLT1's Avatar
bought it from Jason Cromer. I'd really hate to have to do that job again. plus I can't as my apartment complex has already fined me for doing that same job back in December, that was after a written warning for changing my TB. they are **** about that rule here.
Old Apr 8, 2006 | 04:47 AM
Guest47904's Avatar
Guest
Check for spark at the coil and a plug or 2.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
