Car cuts out at part/half throttle and almost instantly happens at WOT.
Old Jul 31, 2007 | 11:55 PM
Built LT1's Avatar
I think it's fuel delivery related. Is it likely a bad fuel pump?
Oh, and when it does pull for the one second under WOT, it pulls like a Civic. Would this also point to a bad or failing pump?
Old Aug 1, 2007 | 12:31 AM
mrmint69's Avatar
A fuel pressure gauge taped to the windshield and a drive will answer your question. When did you replace fuel filter last?
Old Aug 1, 2007 | 12:44 AM
Built LT1's Avatar
I just changed it. I just put my new motor in and this happened. My last motor did this too before I had it pulled and redone. I thought the last time that it was just a blown head gasket causing it. It all happend on my last engine when I activated the nitrous, it just cut out and never worked right again. After that, nitrous would not have been possible to use because it would cut out on motor only.
I'm thinking this problem could possibly be the nitrous kit.
Dec 23, 2014 07:52 AM
Queens94z28
Dec 20, 2014 09:11 PM
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
