car cuts out kinda below 2500rpm, ?
Old Jan 18, 2005 | 08:42 PM
94PurplePearlZ28's Avatar
in any gear especially first slowly accelerating from 1000 to 2500 or so, just driving normal putting around in town, it like spits and sputters some.
as im slowly accelerating (slowly) it will cut out a few times in each gear. then when i get into 6th at any speed below 2500 it kinda cuts out while cruizing. but it i gear down and nail it, it pulls good and strong.
i can be in 6th at 1500 rpm and stomp it to the floor and it dont cut out at all, just gets louder and starts to pull.
but if i am at slight throttle just barely accelerating through the gear then it cuts out.
what do you think it is? plugs? wires? egr? im stumped.
Old Jan 18, 2005 | 09:30 PM
jer811's Avatar
Re: car cuts out kinda below 2500rpm, ?
My 94Z28 does the same thing, I installed new plugs & wires don't help.
Old Jan 19, 2005 | 02:36 PM
BoobSter-lt1-z's Avatar
It Can Be The Coil, Opti, Plugs, Wires,...etc... A Lot Of Veterans Here Recommend You Use A Scanner And See If It Throws Any Codes.
Might Be O2 Sensors...do Some Search On This...try Stumble As The Search Word And You Will Find A Lllooottt Of Entries.....
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
brandboZ28
Jan 31, 2003 06:19 PM
