Car bogs down after a few minutes
Old Feb 9, 2010 | 08:14 PM
95mustangkiller's Avatar
After running my engine for about 10 minutes and getting the engine to a temperature around 200 degrees f. my car starts to die and backfire until it finally just violently shuts off. I checked the fuel pressure while running and its fine so im guessing its something to do with the spark. Any thoughts?
Old Feb 9, 2010 | 08:58 PM
maddog05's Avatar
could be the opti spark
The opti will sometimes act like that....so ill bad fuel and a dozen other things. Check the opti and do a CPM scan.
Old Feb 10, 2010 | 12:00 AM
Camaro350z28's Avatar
possible closed loop problem? o2's?
Old Feb 11, 2010 | 01:34 AM
mrownage426's Avatar
check the MAF. If scanned it should read 6gm/sec to 9gm/sec at idle and the numbers should increase rapidly when you accelerate. could also be dirty.
jayblev95
Jan 20, 2015 01:30 PM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
JasonD
Jul 15, 2002 02:17 PM
