Car bogging and stutering please help!!!!
Old Jun 12, 2013 | 04:33 PM
jhoff9797's Avatar
ok I have a 97 Camaro z28 lt1, following mods are ls1 intake, msd opti and wires, acdelco plugs, 12 bolt rear end, t56 6-speed, ported and polished heads, bigger maf 52mm, bbk throttle body, stage 2 clutch, comp cam 293/313..
now when I drive down the road it stutters a bit until about 2300-2500 then lot of power out of nowhere, and when holding steady speeds it will stumble and jerk a tiny bit until I let of pedel.. and runs fine at wot?
could this be to big of cam? or some sort of vacuum leak or loose plugs?
Old Jun 12, 2013 | 07:18 PM
94Form's Avatar
Re: Car bogging and stutering please help!!!!
Originally Posted by jhoff9797
ls1 intake
huh?
Old Jun 12, 2013 | 07:37 PM
slick1hunting's Avatar
Has it just started acting this way or has it done it from the onset of adding what mods? Is it tuned for the cam and is the maf calibrated correct?
Posted from Camaroz28.com App for Android
Old Jun 12, 2013 | 11:13 PM
CamaroSS30thAnn's Avatar
Are u sure that is the right cam specs. For a 350 that cam is way oversized. I have the gm847 and I'm pushing it with a 355....
Also you said it works perfect at WOT try the o2 sensors since the computer does not use them at WOT.
Sent from my DROID RAZR HD using Tapatalk 2
Old Jun 12, 2013 | 11:14 PM
Originally Posted by 94Form
huh?
Assuming he means the ls1 intake lid and filter not the intake manifold..
Old Jun 12, 2013 | 11:17 PM
Also I'm not to keen about the msd optis they tend to "fall apart" there's nothing like a good lol ac delco
Old Jun 12, 2013 | 11:47 PM
94Form's Avatar
Ah, I see. Thanks
Old Jun 13, 2013 | 06:20 AM
Shangrila's Avatar
I had the same issues after installing new headers. The factory coating inside the headers burned off and ruined the O2 sensors.
Old Jun 13, 2013 | 10:58 AM
Me to
Old Jun 13, 2013 | 05:13 PM
Shangrila's Avatar
Me to
It drove me nuts for a week till I broke down and bought new O2 sensors.
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
