car almost overheated
Old Jun 20, 2011 | 04:16 PM
  #16
jethrobodean's Avatar
Re: car almost overheated
take the belt off and run it and bleed it then put the belt back on....
Old Jun 20, 2011 | 04:18 PM
  #17
94Z28LS1toLT1's Avatar
ok cool thank u i didnt kno you can start the car even if the belt is off
Old Jun 21, 2011 | 09:28 PM
  #18
Originally Posted by Injuneer
That would take us back to post #2........
"A minor cooling problem in the radiator without the A/C on will become a larger problem when the A/C is on, and the air hitting the radiator is warmer."
yep there sure was a cooling problem in the radiator Fred after i took the radiator out first i wrote a thread of the lower radiator hose coming out,when i saw the stem on the radiator it was bent,2nd at the bottom of the radiator on both sides of it has leaks and there are cracks.
After installing the new radiator the cooling system works with the AC on and no overheating so thank u Fred and everybody
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
