Capping off most of the vacuum fittings
Old Jun 26, 2011 | 03:26 AM
Colin's Avatar
Hey guys,
I have a '93 LT1/T56 in a '72 Vega. The car doesn't have power brakes or anything fancy. I basically just need PCV hooked up to the front of the intake manifold and a vacuum hose hooked up to the fuel pressure regulator, correct?
Can I just cap everything else off? What's the easiest way to plug the hole for the brake booster on the driver side? Anything else?
Thanks for the help,
Colin
Old Jun 26, 2011 | 06:48 AM
Kevin Blown 95 TA's Avatar
Re: Capping off most of the vacuum fittings
Any of those fittings you don't need, you can just take them out and put pipe plugs in there - I think they're all 1/8th or 1/4" NPT. You could even get some nice aluminum ones if aesthetics is important to your project.
Old Jun 26, 2011 | 11:53 PM
Colin's Avatar
Kevin,
Thanks for the tips. I bought some vacuum caps but will be getting some aluminum plugs or something pretty for when I get the intake powdercoated. Aesthetics isn't 'really' a focus right now but it will be when I take the motor out (an hour job) later this fall to paint the engine compartment and start the body work.
I used some schematics from other threads and got the PCV system routed and the vacuum line to the FPR run.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sandersen511
Jan 13, 2015 03:49 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
