Can only run one knock sensor..
Old Jun 23, 2011 | 08:04 PM
Colin's Avatar
Hey guys,
I am running a Painless Wiring harness on the LT1 in my '72 Vega. The harness has two knock sensor plugs but the driver side knock sensor location is blocked by my header. What should I do? Leave the knock sensor disconnected or solder both sensor wires together and just run the one sensor from the passenger side near the starter?
Thanks,
Colin
Old Jun 23, 2011 | 11:28 PM
lt1-xjs's Avatar
Re: Can only run one knock sensor..
My 1993 only has one sensor, on the passenger side. I would contact Painless about the wiring, it could be the wrong harness.
Old Jun 24, 2011 | 12:03 AM
Colin's Avatar
I believe the harness has been discontinued. It's 60501 and I bought it a few years ago. I thought it was weird, too, because this harness is basically a TPI harness with a few minor changes.
Thanks,
Colin
Old Jun 24, 2011 | 05:30 AM
The Corvettes and (I believe) the B-Body LT1's had dual knock sensors. If you are using an F-Body PCM, its only expecting a single knock sensor to be connected.
Old Jun 24, 2011 | 04:01 PM
19z28camaro02's Avatar
Didn't 93 NOT have a knock sensor? I could be wrong, but I heard somewhere they didn't.
Old Jun 24, 2011 | 04:25 PM
Stl94LT1's Avatar
You're wrong. 93 didn't have a removable knock module.
Old Jun 24, 2011 | 05:54 PM
I knew that. They had the E-proms. Did they have the threaded one on the passenger side of the block?
Old Jun 24, 2011 | 11:29 PM
The 93's are exactly the same as all the other years, with regard to the location of the knock sensor.
Old Jun 27, 2011 | 12:14 AM
Colin's Avatar
Thanks for the help, guys. I have threaded locations on both sides of my block. I called Painless and they said one of the knock sensors is redundant and I can either snip it, solder the two wires together, or remove one from the harness by unpinning it from the harness at the PCM. I haven't decided which is best yet as I haven't looked at a PCM pinout.
jayblev95
Dec 1, 2014 06:55 AM
thenewkid
Nov 27, 2014 09:41 AM
Lions3
Apr 11, 2003 10:55 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
