Canton pickup work with the stock oil pump?
It was reccomended that I get a Canton pan for my 383. I've already bought a stock GM pump & pickup under the impression that I was going to run my stock pan.
But, if I get a Canton pan, I need to get the Canton pickup to go with that. But, will the canton pickup work in the stock pump?
Dave, I am in the same boat as you I think. I am considering the Canton pan also. I will be running a blueprinted Melling pump and need to know the same info about the pickup. Also, does anyone knows if the newer version will clear the AS&M y-pipe.
LOL
