Canton Pan & Windage Trays???
Old Mar 2, 2004 | 10:33 PM
InjectedSS's Avatar
Was talking to a buddy of mine and he was saying that it's not necissary to even run a windage tray with a baffeled pan like a canton pan, cause it's already built in.. Is this true? I asked him what if I left the tray in if it would matter and he said it more than likely won't even fit..
NO it's not a stock windage tray either
Old Mar 2, 2004 | 10:50 PM
Rock_N_Rolla's Avatar
I'm also interested in this discussion ...TTT
Old Mar 3, 2004 | 01:23 AM
InjectedSS's Avatar
Already talked to JordonMusser like I should have done in the first place He informed me that the canton pan DOES have a windage tray built in and that the aftermarket one's aren't necissary and/or more than likely won't even fit...
I keep forgetting that the only questions that people can answer in LT1 Tech are "what's the best exhaust and what kinda intake should I get"
No wonder where all the FAST 14 sec f-body's I always see at the track come from
Old Mar 3, 2004 | 01:36 AM
Well I've just spent 3 hours jacking up the motor and dropping the K member ...I get the canton (242t) pan finally up under the block and guess what ...the pan won't clear the Gm windage tray ...arghhhhhhhh. So I guess you're right ...no Gm windage tray. I'm going back out to remove it.
Later.
Old Mar 3, 2004 | 01:43 AM
InjectedSS's Avatar
Later.
Yup, it's funny how NO ONE ELSE knows these things
Anyways, how's that pan look?? I know I heard that they had all kinds of problems back in the day but I guess canton has revised it or some $hit... What's the 411 on that thing?
Old Mar 3, 2004 | 01:56 AM
97 RedSS's Avatar
......maybe if you tried a "search" you would find some good info..
Cody
Old Mar 3, 2004 | 02:00 AM
InjectedSS's Avatar
Cody
Hell yea dude, there's TONS OF GOOD info........ About the BEST exhaust and BEST intake....... and BEST oil........
Old Mar 3, 2004 | 02:06 AM
Well actually cody had some good insight on the Milodan windage tray and the stock pan thanks M8. ...but now I've removed the Gm baffle/windage tray the Canton pan fits up OK. The pan is not a very well made piece I've deburred it etc ...but it's GONNA FIT !!
I'm still under the car 3.00am ..later
Old Mar 3, 2004 | 02:07 AM
97 RedSS's Avatar
Injected~
Apparently you dont know too much then....
Old Mar 3, 2004 | 02:27 AM
InjectedSS's Avatar
Injected~
WOW maybe some day I will be as smart as you then
Old Mar 3, 2004 | 02:28 AM
InjectedSS's Avatar
Where isn't it fitting into place at?? What exactly are you needing to grind down on etc?
Old Mar 3, 2004 | 04:17 AM
It's just not 'finished off" very well, But it's on ..kinda. Bed. 5.00am
2QUIK6
Sep 17, 2016 02:31 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
wbspoon
Sep 19, 2015 08:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
