Canton Fabbed Valve Cover Install ?'s
Old Jun 29, 2006 | 06:39 AM
  #16
Eric@Victory Racing's Avatar
Re: Canton Fabbed Valve Cover Install ?'s
If you guys are interested we will run a GP on them. Let us know.
Old Jun 29, 2006 | 10:03 AM
  #17
blown383's Avatar
I'm interested for a GP!
-B
Old Jun 29, 2006 | 03:41 PM
  #18
97WS6SCharged's Avatar
I'd be interested if they will clear a set of stud girdles.
Old Jul 5, 2006 | 04:07 PM
  #19
blown383's Avatar
I also forgot to mention but... how are you guys running the plug wires with those long tubes and valve covers?
-B
Old Jul 6, 2006 | 07:46 PM
  #20
NVRLATE's Avatar
Well I finally got everything back together today and started it up for the first time and to my dismay I hear a loud knocking from my passenger side valve cover. I'm pretty sure it's one of the rockers contacting the cover but I'm not sure which one. I guess I'll have to wrestle that bastard off and see if there's any marks. Even if I can see where it's hitting I'm not sure what I can do about it. The walls of the covers are not that thick.
Old Jul 7, 2006 | 08:56 AM
  #21
"White Knight"'s Avatar
I am interested in a GP with these covers. I want to try these out.
Old Jul 7, 2006 | 09:54 AM
  #22
On the motor we just used them on, we had to clearance the area that is stepped in for the alternator. It was just clipping the c-clip of the front most rocker arm.
Old Jul 7, 2006 | 09:56 AM
  #23
LALT1's Avatar
I would be very interested in a GP as well.
Old Jul 7, 2006 | 10:58 AM
  #24
Sweetred95ta's Avatar
-B
I'd like to know this as well. You definitely can't see the plug wires in the pictures.
Old Jul 7, 2006 | 12:31 PM
  #25
Jeff95TA's Avatar
Same on mine. Canton adjusted the stepped area for me which worked - it now clears the rocker arm. But now it hits the alternator. Doh! Going to try making a bracket to rotate the alternator up about an inch. We'll see how it goes.
Note that this is with the Pro Mag rockers which are a fairly wide body.
Old Jul 7, 2006 | 12:35 PM
  #26
Same here.
  #27
blown383's Avatar
How much clearancing is needed with the valve covers and the CC Pro Magnums? A set of $200 valve covers should not need any tweeking!
-B
Old Jul 7, 2006 | 12:36 PM
  #28
Could you just grind a little off the alternator or is it a lot off?
Old Jul 7, 2006 | 12:42 PM
  #29
Very minimal clearancing on the step corner of the step. It was barely touching the c-clip on the the front rocker.
-B
Old Jul 7, 2006 | 12:43 PM
  #30
We had no issues with the alternator fitting.
