Cant run self-aligning rockers on any afr heads?
Old Mar 11, 2009 | 09:58 PM
Nissenexcavating's Avatar
Im trying to find a set of afr heads and they all say they will not work with self aligning rockers. Are s/a rockers really that bad why wouldnt they work
Old Mar 11, 2009 | 10:02 PM
PHINES LT1's Avatar
they dont work with s/a rockers because the heads come with the guide plates already installed. if a person is going to be running aftermarket heads and the performance potential that they offer, then the nsa rockers are probably a better set up.
Old Mar 12, 2009 | 07:30 AM
DAVE00's Avatar
Ummm, maybe this is new for AFR but my AFR190's (older versions) that I have been running since 99' had the option for guide plates or not. I am currnently running 1.6 Crane Gold S/A rockers with no probs.
Old Mar 12, 2009 | 12:22 PM
Kevin Blown 95 TA's Avatar
You can run the SA rockers on them, no problem. If they come with the guide plates, just remove them and use machine bushings or some other high quality flat washer under the studs.
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
