Cant get collectors to seal, use 2 gaskets?
Old Jul 28, 2004 | 07:50 PM
jchevy's Avatar
I cant seem to get the collectors to seal on my SLP hearders. Is it ok to try and use 2 gaskets to get the y-pipe to header joint to seal? Or will that for sure leak?
Old Jul 28, 2004 | 08:08 PM
simple's Avatar
Re: Cant get collectors to seal, use 2 gaskets?
orange hi-temp copper RTV on both sides of the gasket (works for me)
what gaskets are you using?
Old Jul 28, 2004 | 08:43 PM
jchevy's Avatar
I am using GM gaskets. Wont the RTV just burn away after awhile?
Is it worth a try to just use 2 gaskets or will that cause it to get worse?
Old Jul 28, 2004 | 08:45 PM
bdc95ta's Avatar
the hi-temp shouldn't, burn away that is
Old Jul 28, 2004 | 09:45 PM
revtime's Avatar
Mr Gasket Copper Seals.
I put these gaskets on my headers and my collectors and have not had any leaks.
Old Jul 28, 2004 | 09:48 PM
jchevy's Avatar
I need to use a factory shaped gasket with these headers there is no aftermarke alternative as they are a funky shape.
Old Jul 28, 2004 | 10:02 PM
bdc95ta's Avatar
Slp sells gaskets.
-b
Jeff1904
Jun 5, 2016 05:00 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Pwilson59
Sep 3, 2015 08:47 PM
Bails098
Aug 17, 2015 05:15 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
