?????? Cant figure this one out.. Please help
Old Dec 5, 2009 | 02:50 PM
brentrich_2006's Avatar
ok so i recently started having problems with my car and it just wouldnt start very easy. I took it to the local shop and had it scanned and it threw a mass air flow sensor code, i got a new M.A.F. and now the car wont even try to start, i put the old one back in it to see if it would even try and i have had no luck with either one any more, What else could be causing this is there another sensor that could cause that code or did i get a bad part? I ordered the M.A.F. from GM and it is a AC Delco sensor. its really starting to get me confused its been down about two weeks now and i dont know what to do. Any help is much appreciated
Old Dec 5, 2009 | 03:01 PM
bubba4's Avatar
Did you clear the codes when you installed the new maf (If so, has it set the same code or any others). LF
Old Dec 5, 2009 | 03:06 PM
well i got the code cleared right after i changed the sensor but the car wont even start to see if it is still throwing the code or not. I have no idea if it is still throwing it or not
Old Dec 5, 2009 | 03:19 PM
bubba4's Avatar
Try scanning it again also check for fuel and spark. Shoeboxes site has a lot of info for doing this. LF
Old Dec 5, 2009 | 05:50 PM
ok well i have a new update i went and shot starter fluid into it and it started but it didnt want to run right for a min or two, and as soon as it gets cold again i have to hit it with starter fluid again is there some sensor or something that runs better when it gets warm?
Old Dec 5, 2009 | 06:13 PM
jchevy's Avatar
Will it start with the MAF unplugged?
Old Dec 6, 2009 | 12:01 AM
bubba4's Avatar
That sounds like the engine coolant temp. sensor. Shoebox has some trouble shooting info on this sensor on his site. LF
Old Dec 6, 2009 | 12:23 AM
bubba4's Avatar
I said ect sensor in my previous reply because my 95 had the ect sensor go out. Mine would start after many tries and but I had to hold the engine at 3000rpm for a couple of minutes are it would shut off , it sounded like it was flooding. My scan tool was showing the ect sensor at a low temp(5 or 10 deg F) and it was a 90deg F summer day. I don't think mine threw any codes. LF
Old Dec 6, 2009 | 10:44 AM
There's only one MAF code in OBD-I, and that's for the electrical circuit. Check the harness connector for damaged pins or wires. Check the pink wire in the MAF harness connector for 12V, measuring to the black/white ground wire in the connector.
You can scan the PCM for codes any time the key is in the "run" position. The engine does not have to be running.
Old Dec 6, 2009 | 02:52 PM
well i checked the wires for the voltage and it was fine i am going to try and make it to the shop again to get it scanned but i am not sure if i can make it there. But it will be tomorow before i can try that seeing as how its sunday lol but i didnt know if this just sounded like another problem other than the mass air flow, the guy i took it to didnt tell me the code he just said that is what it was so i just took his word for it and just wasted money on that cause it didnt fix the problem and he is the only guy around here that has the obd 1 scanner that has the harness to fit the car
Old Dec 6, 2009 | 02:58 PM
and i just put a new coolant sensor in it about a month ago but i got it at auto zone so it is prob junk... just a thought
Old Dec 6, 2009 | 03:58 PM
Might want to check the fuel pressure.
Old Dec 13, 2009 | 01:52 PM
well i got it figured out all it was was the crappy auto zone coolant sensor i got a new one in and it is running good thanks for the help
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
NewsBot
Sep 14, 2015 02:02 AM
