Can't Do a burn out. Need help!!!!!!!
Old Feb 26, 2005 | 10:42 PM
  #16
MustangEater82's Avatar
Re: Can't Do a burn out. Need help!!!!!!!
whoa dude...
more air will make a burnout easier...
your car is likely fecked up... I coudl do smokey burnouts with my 2.8L, 3.4L, and 3.8L v6 with no problmes...
the 3.4L and 3.8L both had limeted slip even, hell the 3.8L is running 275s in the rear.
I got a feeling your problem is #6, with your car setup and driving.
Old Feb 26, 2005 | 11:47 PM
  #17
sskevinm's Avatar
Since when did automatics come with ASR????
Old Feb 27, 2005 | 01:27 AM
  #18
TransAm2k4's Avatar
Theirs got to be a problem. The LT1 should do a burnout even with M/T Et streets. And i don't see how it could be driver because it's simply tooooooo easy to do a burnout. Must be something mechanical. Just stump on the gas. I could do burnout with a 3.4L Grand Am Auto.
Old Feb 27, 2005 | 03:19 PM
  #19
DavesLT1's Avatar
I might say some of #6 with maybe something else wrong with the car. I do burnouts barely trying and sometimes leave rubber when I don't mean to, and I am not heavily modded.
Old Feb 27, 2005 | 04:52 PM
  #20
crazy_jackalope's Avatar
If you have 2:73's on a stock car it will be a little harder to do a burnout with good rubber and a good street. I have the 2:73's with an almost stock car and if I stomp on it it spins a little but it doesn't do anything close to a burnout. To do a burnout I have to use some powerbraking.
Old Feb 27, 2005 | 05:51 PM
  #21
LUDA0840's Avatar
Just came from the mechanic and he said that the whole brake system is corrupt. the abs and the asr are not even working. what a mess, the main computer is corrupt, something like that.
Old Feb 27, 2005 | 07:53 PM
  #22
that sucks. My abs doesn't work, but I don't worry about it because I don't like abs anyways. I like to control my own brakes. I found that one out after I bought the car and realized the abs inop light was on. It had some black tape over the light to cover it up. The car seems to brake fine though. I can lock up all 4.
Old Feb 27, 2005 | 08:04 PM
  #23
1quikZ's Avatar
I vote for #6
Old Feb 27, 2005 | 08:51 PM
  #24
Heatmaker's Avatar
Advanced Member
Are you sure your not acutally driving a Mustang instead of a Camaro?
ANyhow.... what do yo umean you can't do a burnout? Can't you just hit the gas and let the tires smoke up? I haven't dropped the clutch to do a burnout since I had a 4banger...
Old Feb 27, 2005 | 08:52 PM
  #25
izzyz28's Avatar
Put the shifter into neutral, floor the gas until you hear the engine popping(this is good), and then shift into R for Race. You'll be doing burnouts in no time! You may want to call Warren Johnson when you get it working so he can take that bad boy down the track, because once you put in in race mode it'll be running sevens easy.
Old Feb 27, 2005 | 08:57 PM
  #26
LUDA0840's Avatar
A Gt mustang beat me today, which really sucked, something is wrong with my car; it loses too much power. A mustang gt beat me .
Old Jan 28, 2006 | 08:44 PM
  #27
LUDA0840's Avatar
ha this suck!!! old times. a year later and so much has been done to the car!!!! now a forged 355 is on its way thanks to a spun bearing!!! I love this site!!!!!!! Thanks everyone for helping me out!!!
Old Jan 29, 2006 | 01:12 AM
  #28
JonZ28SS's Avatar
Originally Posted by Eck
Too much air in the tires can keep you from doing a burnout? Uhh... first off, I would think any LT1 could do a burnout, regardless of how much air is in the tires. Second, I thought more air would give less traction when compared to a tire with less air that puts more tire to the
Agreed. More air means less traction, hence more spin! +P Rocket science. I reduce rear tire pressure when I take it out to the streets to gain rear traction.
Old Jan 29, 2006 | 02:34 AM
  #29
blue94's Avatar
same here
Old Jan 29, 2006 | 04:00 AM
  #30
skunktones's Avatar
eck u are 1000 percent right sir more air makes the tire harder there -4 yes it would be easier to do a burn out yea i would say#6 also my car has 147000 and it will smoke the tires off if i wanted to do so as a rule of thumb less air= more traction
