cannot get oil pressure gauge to work
Old Jun 21, 2006 | 08:51 PM
ghost stripes's Avatar
it worked when i pulled the engine but i broke the oil pressure switch while pulling it but i bought a new one ...now i just built this engine and im scared that the engine may not have oil pressure ....now my question is how can i check to see if its the switch or the engine ...like i said both are brand new so it could be either and i dont want to lock my engine up to find out which one it is any help will be appreciated
Old Jun 21, 2006 | 08:54 PM
rich152's Avatar
Re: cannot get oil pressure gauge to work
get a manual pressure gauge.
Old Jun 21, 2006 | 09:30 PM
Disifer's Avatar
What he said. There's a plug right above the oil filter on the 94+ Lt1's that you can hook up a manual gauge
http://shbox.com/1/aux_oil_port.jpg
Make sure that the harness is all right. I had a problem where my CTS on my 89 TA kept giving me trouble. It turned out that the female part of the wiring harness was bent and not making contact
Old Jun 21, 2006 | 10:17 PM
I used an SBC priming tool and hooked a meter to the pressure sensor. I was able to take the resistance readings while priming and calculate how much pressure that roughly equated to.
Old Jun 22, 2006 | 04:25 AM
thanks guys for the info i believe i will do the aftermarket oil gauge ....im not smart enough to do what shoebox is talking about ......
Old Jun 27, 2006 | 04:59 PM
rich152's Avatar
what shoebox is saying isnt hard. get a mulitmeter and a priming tool and prime the motor. have a buddy put the leads on the 2 terminals inside the end of the pressure sensor while you are priming. and the reisistance should change if you are getting pressure.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
