Can you use stock rods in a 383 stroker LT1?
Old Feb 23, 2006 | 01:07 AM
bipolar's Avatar
Or does it take special stroker rods? What about the pistons? Thanks..
Old Feb 23, 2006 | 03:45 AM
camaronutt's Avatar
Re: Can you use stock rods in a 383 stroker LT1?
I don't think it uses stock length rods. I'm not sure on the specs of it though. I'm in the learning stage yet. I remember the Gen I engine guys saying a 400 crank and rods in a .060 over 350 block will make a 383, still don't know if that is even right.
Old Feb 23, 2006 | 05:58 AM
bipolar's Avatar
No, 60 over would be a 388, 30 over is a 383.. But Im still learning too.
Old Feb 23, 2006 | 06:10 AM
97WS6NY's Avatar
you COULD use stock rods in a stroker, rods don't create the stroke, the crank does. But if you are going to build a stroker, why wouldn't you buy some decent rods?
Old Feb 23, 2006 | 07:43 AM
CANTONRACER's Avatar
You can use them and for the power most people make, the stock rods are fine.
Old Feb 23, 2006 | 09:08 AM
97WS6SCharged's Avatar
As long as the counter balance of the crank will clear a 5.7" rod, you can use the stockers. Pistons will be determined by the crank and rods you use.
Old Feb 23, 2006 | 12:25 PM
firebirdStud's Avatar
I used my stokers for a budget 383. Now, I am yanking them out and going manley sportsman 6 inchers. I figure I spent all this money into the motor, I would hate to have a rod get bent or something.... But, I am a little **** with my money. Its easier to spend 400 now on new rods, or have to buy a new crank, block, pistons, maybe heads... so, its all in what you want to do. You will never be sorry to upgrade now while its easy!
Old Feb 23, 2006 | 05:27 PM
96capricemgr's Avatar
I know of at least one mid 10 second 383/spray b-body running stock rods and has been for years.
Old Feb 23, 2006 | 07:14 PM
ABA383's Avatar
Mine has Oliver billet steel 5.85"...11 years old...They are a little pricey, but they are very strong/durable and create a good rod angle within the cylinder bores...I have been accused of having a way overbuilt motor...Guilty as charged...
--Alan
Old Feb 23, 2006 | 07:38 PM
FastZinTennessee's Avatar
Doing it right the first time sure beats doing it twice. From a frustration and $$ standpoint.
Old Feb 23, 2006 | 08:07 PM
MachinistOne's Avatar
Those Manley's are good rods, you will be happy with them. You will need 1.25 comp height pistons and a re-balance, so it's not really $400...
Old Feb 23, 2006 | 08:19 PM
ssnorm96's Avatar
GM Performance Parts sells the stock LT1/LT4 rods and their claim is that they are good in engines producing up to 450 HP. Stockers are fine unless you are gonna get silly with a power adder, IMO.
Old Feb 23, 2006 | 09:43 PM
GMRL's Avatar
GM uses the PM rods in their 383 crate motor, along with a forged crank and Hyp. pistons.
oldschool
Feb 9, 2016 09:21 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
deadmanrunning
Jan 3, 2015 01:12 PM
