Can you test an o2 sensor?
Old Dec 26, 2003 | 03:58 PM
Birdman7389's Avatar
Like maybe with an ohm meter or something?
Old Dec 26, 2003 | 09:03 PM
OBE1 95Z28's Avatar
An O2 sensor can give you the right reading statically (ohm reading) but still be bad. They need to monitoring dynamically. A "healthy" O2 sensor will bounce back and forth rapidly between approximately 100mV and 800 mV when heated to operating temperature. They sit at 450 mV when cold. A slow moving sensor is signs of it dying. As O2 sensors "age" with mileage, they get coated and can't act quickly to changes in oxygen concentration. If they are high mileage O2 sensors I would just replace them even if that wasn't your only problem. You can buy GM sensors for $35 each (heated style) from Dal, Jason Cromer or Team Chevrolet.
Old Dec 26, 2003 | 09:15 PM
well, I've got a pair of them from cromer with about 200 miles on them in the car now, but I've been having some problems with my headers that i just installed. One of the other guys had the same problems I'm having and he says his o2's were bad. I just wish I could check em without buying new ones I cant really afford a scanmaster at the moment so......
Old Dec 26, 2003 | 09:33 PM
SWINGRRR's Avatar
http://www.thirdgen.org/newdesign/tech/o2tuning.shtml
Kinda generic, but hopefully this will help you.
crAzy95z28's Avatar
Birdman, i had the same problems as you the other day..if you get a SES light then your o2 is bad...i replaced mine and now its fine..go and buiy some new ones...if thats not it, then im terraible sorry man..
but i have a feeling its 95% correct
Old Dec 26, 2003 | 09:35 PM
SWINGRRR's Avatar
Also, you can read the O2 votlage with a $65-$95 dollar ALDL cable and Datamaster for free.
www.wotelectronics.com for the cable
and www.ttspowersystems.com for the program
O' you need access to a laptop.
Old Dec 26, 2003 | 09:49 PM
crazy... your the one I was thinking of. I'm just kinda hesitant that it would be the o2's because they seemed to work fine before the install and have maybe 200 miles on em. I'm gonna try some new ones on monday though....
Old Dec 26, 2003 | 10:06 PM
cool, i shot him an email, will probably pick up that cable. thx
jj_burchiel
Mar 21, 2015 12:51 AM
naaz90
Jul 27, 2002 08:22 AM
