Can you run 1.6 rr's with stock springs (LT1)
well, can you... thats what i am running now because i can't afford springs yet...
is this going to damage my valvetrain or hurt my performance?
i have comp pro mag NSA 3/8" stud roller rockers and 47000 miles on the engine...
thanks
thanks
so would headers and EWP then... i read somewhere that they were just a bolt on upgrade and that anything lower on the valve train would take you away from stock...
who knows the rules though...
You're mixing 2 issues, first you ask if it will hurt your engine, then you want to know if it will still be stock. As far as hurt your engine, you run the risk of coil bind that can hurt your engine. My friend broke 2 push rods after 10K miles of running 1.6 RR's without changing the springs. I understand that a lot of guys don't have issues so it's up to you, do you feel lucky? As far as still be considered as stock, it would depend on the rules of the class you're trying to compete in.
You can run the stock springs. With a completely stock set-up... Installed height = 1.78". Coil bind height = 1.26" This leaves 0.52" of total (theoretical) lift. The stock cam has 0.46" of lift at the valve. This leaves 0.06" of clearance for the spring (before coil bind). Most sources will tell you that 0.06 (or greater) is a "safe" amount of clearance.
When you go to 1.6 rocker arms, the lift increases to 0.49". This leaves 0.03" of clearance on the springs (before coil bind), which is less than the 0.06" that is the generally accepted minimum.
Can you get by with 0.03" of clearance? Maybe, probably, but there must be a reason why the 0.06" minimum is so widely considered the standard...
I'm running my engine with 1.6rr's and stock springs. I just turned 51K on the clock. I'm not recommending you do it, but I decided to.
The LT4 springs seem to be very good & very inexpensive for this type of application. If the work of changing out your springs is not an issue, then I would definitely change out the stock ones.
You should be fine to run 1:6 rockers. I have had them for well over 40K on stock springs. One thing I did was get hardend pushrods, they were cheap and easy just incase the stock ones were weakend over time. And unless your running professional class racing who cares if you call the motor stock or not. But like most people I would say once the valve covers are off its not stock anymore.
oldschool
Feb 9, 2016 09:21 PM
