Can you put TOO big of injectors in?!---
Old Feb 21, 2006 | 11:23 AM
AlwaysCode390's Avatar
Question Can you put TOO big of injectors in?!---
What happens if you do? I am not sure if I need 84 # or 96 # in my b&m superjection for a 500hp blown setup on my 67 327. There are only FOUR injectors and not eight. Let me know what you reccommend. I am about to buy them off of ebay and need to know ASAP....THANKS GUYS---
Old Feb 21, 2006 | 11:58 AM
97bowtie's Avatar
Re: Can you put TOO big of injectors in?!---
I can't say I know much about the superjection setup, but you need to make sure the injectors are rated at a fuel pressure you are able to run and maintain throughout the full RPM range of the motor. For a 500 HP setup, and 4 injectors, the 84# injectors should work OK. As long as you can program the injector size in the ECM, there shouldn't be any problem going with the 96# injectors. Given that you only have 4 injectors VS the 8 we are used to dealing with, you will need twice the injector. I'd probably run the 96# injectors, but given my limited knowledge about that injection system, take my advice for what it's worth.
Old Feb 27, 2006 | 02:06 PM
Thank you very much for your help....I think you are right!!! ---
Sergio
Jan 27, 2016 04:27 PM
meissen
Jun 1, 2015 07:59 AM
Fatdog2
Feb 13, 2015 08:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
