Can you put an opti on wrong?
Old Jun 27, 2004 | 04:31 PM
96z's Avatar
96z
As long as you put the cam dowel in the right slot on the back of the opti does the position of the cam/opti matter when putting the opti on?
Old Jun 27, 2004 | 04:32 PM
Spinner's Avatar
No, as long as the dowel is in the right hole, the opti will be in correct time.
Old Jun 27, 2004 | 04:38 PM
96z's Avatar
96z
Cool, thats what I thought.
Old Jun 27, 2004 | 05:48 PM
You can, however, get the dowel pin in the wrong slot on the back of the opti, so be careful.
Old Jun 27, 2004 | 06:37 PM
96z's Avatar
96z
Id made sure not to do that shoebox. Is it possible to test the optical portion of the opti to the best of your knowledge? I know its impossible to tell but how often does the optical portion go bad in a opti that is goes bad?
Old Jun 27, 2004 | 06:48 PM
Ryan94ZA4's Avatar
Typically, the high voltage section will fail first. However, the optical portion has been known to fail also.
Ryan
Old Jun 27, 2004 | 07:23 PM
96z's Avatar
96z
Well I was having high RPM misses so Im guessing the high voltage portion was on its way out. I wanna see if my opti is salvagalbe to use with the new delteq unit...
Sergio
Jan 27, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
capebuf
Jan 13, 2015 07:22 PM
Injuneer
Dec 15, 2014 09:36 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
