can you prime your oil pump without taking the intake off?
Old Sep 2, 2006 | 11:06 PM
  #31
1racerdude's Avatar
Re: can you prime your oil pump without taking the intake off?
Originally Posted by 96LT1TX
so is there a for sure way to prime the oil pump? I dont see a for sure way yet, my intake manifold is off waiting to prime.
thanks
First ya get a priming TOOL.
Then insert TOOL
Turn with a drill until oil comes out the pushrods from the TOOL being turned.
DO NOT TURN THE CRANK DURING the TOOL turning.
Remove the priming TOOL and finish assy and install.
Put TOOL in storage and crank it up and go have fun if ya have OP.
Old Sep 2, 2006 | 11:18 PM
  #32
Heatmaker's Avatar
Advanced Member
You can rent the tool for less than 12 dollars at Autozone, and it really isn't hard to do.
Old Sep 2, 2006 | 11:24 PM
  #33
1racerdude's Avatar
Kee rect--but ya gotta have the TOOL.
Old Sep 3, 2006 | 08:38 AM
  #34
cehan's Avatar
Then insert TOOL
Why is it bad to turn the crank during the time the tool is pumping up oil pressure? I would have thought that doing so would insure oil gets to all the surfaces of the pressure lubricated parts
Old Sep 3, 2006 | 11:04 AM
  #35
Dave89IROC's Avatar
no idea, definately won't hurt anything
Old Sep 3, 2006 | 12:11 PM
  #36
TransAm396's Avatar
isnt the oil drive connected to the cam with gears? im confused on how you do t his with the tool?
Old Sep 3, 2006 | 12:50 PM
  #37
Heatmaker's Avatar
Advanced Member
The purpose of the oil pump drive is to turn the oil pump drive shaft as the cam gear spins it at a certain RPM. When you pull out the Oil pump drive gear, and use the tool to prime the pump your turning it manually, so you can get a faster spin on the oil pump drive. You can't get the same speed from just cranking it without the plugs. That's the advantage of the tool.
Old Sep 3, 2006 | 12:56 PM
  #38
TransAm396's Avatar
oh you take out the gear...ok just making sure
Old Sep 3, 2006 | 01:14 PM
  #39
1racerdude's Avatar
Ya may be turning it and wiping assy lube off before oil gets there.
When I assemble I turn it over no more than 1 rev after the pistons are in to keep from scratching up the bearings or anything else.
Old Sep 3, 2006 | 02:41 PM
  #40
Dave89IROC's Avatar
I spin the pump until i see oil at one (or more) pushrod/rockers, then i turn the crank, 1/2 turn
Old Sep 3, 2006 | 04:55 PM
  #41
1racerdude's Avatar
That may be OK but NOT necessary.
Once it is primed it's like cranking it after being left overnight.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Darth Xed
Jul 1, 2002 03:22 PM
