can you prime your oil pump without taking the intake off?
Old Jun 22, 2006 | 04:51 PM
ghost stripes's Avatar
looking at the drawings im not sure if i can
Old Jun 22, 2006 | 05:04 PM
Dave89IROC's Avatar
Re: can you prime your oil pump without taking the intake off?
no, the intake covers the hole
Old Jun 22, 2006 | 05:30 PM
arcticz28the383's Avatar
You actually can. but you need a special tool to do it. You need an adapter that fits on where you put the oil filter, and then you run pressurized oil into it. Never done it before, but thats what ive read in the 'how to build lt1/lt4 engines' book.
If this is a new motor and you havent primed it at all, your going to have to remove the intake and actually spin the pump. The above way is only if the engine has been sitting for a couple weeks or more fully assembled, but hasnt been started yet (but has already been primed once before with the pump).
Old Jun 22, 2006 | 07:58 PM
i have built a number of engines and never had to prime the oil pump ....why this one?
Old Jun 22, 2006 | 08:11 PM
sam pace's Avatar
is it in the car or on a stand.
if its on a stand flip the motor over and fill the sump.
fill the oil filter up. put the oil pan on.
when its back in the car disconnect the coil wire and turn over the motor till you get oil pressure. or just take the intake off.
Old Jun 22, 2006 | 08:13 PM
its in the car running ...how hard is it to take the intake off with it in the car?
Old Jun 22, 2006 | 08:18 PM
sam pace's Avatar
not too bad.
20-30min at the most.
do it right or do it twice (rebuild)
Old Jun 22, 2006 | 08:21 PM
i dont have to drop my heads or exhaust or anything do i?
Old Jun 22, 2006 | 08:28 PM
sam pace's Avatar
take off the intake, fuel rails egr tube ect. take the bolts that hold it on.
if its running why do you need to take it off? are you getting no oil pressure?
if you have no experience doing this then you should not do it. it will be more of a mess than what you are expecting.
Old Jun 22, 2006 | 08:31 PM
i have done it and its running but doesnt have any oil pressure
Old Jun 22, 2006 | 08:43 PM
sam pace's Avatar
no dropping heads or exhaust.
did you put the oil pump rod in?
Old Jun 22, 2006 | 08:45 PM
Javier97Z28's Avatar
Moderator
If it's running and doesn't have any oil pressure, priming it is not your problem. Priming is to prevent a dry start in the system.. the system will eventually get pressure with the engine turning.
Please break down the details of your motor, oil pan, oil pump, oil drive, oil type/weight so we can diagnose.
Old Jun 22, 2006 | 08:58 PM
sam pace's Avatar
thank you
Old Jun 22, 2006 | 09:02 PM
cehan's Avatar
Bad idea on a new motor that's never been primed .
Old Jun 22, 2006 | 09:16 PM
Josh'95Z28conv's Avatar
Why? Pro's do it every day Thats what Ill be doing soon...
