can you clean 02 sensors
Old May 15, 2011 | 09:34 PM
remaxracer45's Avatar
if you remove the 02 sensors can you clean them, if so with what? car has allways run a little rich thought i'd take em out and clean them if needed. not alot of miles on them
Old May 15, 2011 | 09:35 PM
Re: can you clean 02 sensors
The sensing elements are surrounded by a metal shield with tiny slots. Not sure how you would clean them.
Old May 16, 2011 | 12:22 AM
MikeGyver's Avatar
I've cleaned the soot out of them with brake cleaner before. Just make sure they're not hot and let em dry out after. It won't fix your problem btw and it's best to not mess with them unless they're cycling very slow when warmed up. What makes you think it's running rich anyway?
Old May 23, 2011 | 11:52 PM
had a bad opti, they have carbon on them and back when the opti was bad the plugs were carboned as well, fixed the problem and got a tune
Fatdog2
Feb 13, 2015 08:19 PM
Jazsun
Dec 29, 2014 12:14 PM
