Can You Change The Oil Pump Without Pulling The Engine?
Old Jul 2, 2006 | 02:44 PM
ghost stripes's Avatar
I THINK I WILL HAVE TO PULL IT AND ITS GOT ME CRAZY .....oops sorry about the caps
Old Jul 2, 2006 | 03:19 PM
yotaman96's Avatar
Re: Can You Change The Oil Pump Without Pulling The Engine?
You can lower the K member without taking the bolts completely out. That will barely give you enough room to take the oil pan off. Would really help if it's on a lift.
Old Jul 2, 2006 | 03:31 PM
Severous01's Avatar
if you have access to a lift and a tranny jack you can lift the engine with the motor mounts loose. if you dont have access to a lift, put the car on stands, get a cherry picker and lift the engine from the front with the mounts loose. you can get the tranny pan off without dropping the k-member or without pulling the tranny...i've done it to replace my main bearings.
Old Jul 2, 2006 | 03:42 PM
matLT1's Avatar
You can lift the engine just enough to get the pan off without dopping the frame.
Old Jul 2, 2006 | 06:30 PM
CamaroBoy96Z28's Avatar
Thats what I did. Even though it would have been pretty easy at the time to just pull the engine I did it in the car. Its just a small pain to wiggle the pan out.
Old Jul 2, 2006 | 10:14 PM
96capricemgr's Avatar
Why do you want to replace the pump? If pressure is low bearing should be suspect LONG before the pump and the stock pump is very good so blindly "upgrading" it is if anything asking for trouble.
Old Jul 3, 2006 | 02:11 AM
well its a brand new engine new oil pump new everythingi would like to change the oil pump and that be it...im basically doing lil things first
Old Jul 3, 2006 | 08:53 AM
CANTONRACER's Avatar
Why?
Old Jul 3, 2006 | 10:12 AM
ulakovic22's Avatar
Why do you want to change the pump if it's new?
Old Jul 3, 2006 | 10:23 AM
blackztpi's Avatar
sbc oiling systems do not go bad under proper car. think about it...the oil pump is a couple gears moving. thats all it contains. there's not much that can go wrong.
Old Jul 3, 2006 | 10:29 AM
Tricked-Out-Toy's Avatar
you can change the pump fairly easy with the engine in the car, make sure you put the engine in the 6 oclock position, (I think its 6:00) this pulls the counter weight up out of the pan which makes it ALOT easier to remove.
Old Jul 3, 2006 | 06:26 PM
thanks i will try this
Old Jul 5, 2006 | 03:50 PM
"White Knight"'s Avatar
I don't get it
He must not be telling us he forgot to install it before he put the motor in the car.....lol
Old Jul 5, 2006 | 04:49 PM
the pump is in the car im not sure why i dont have oil pressure...the question above was can you CHANGE the oil pump not install one......do you get it now?
Old Jul 5, 2006 | 06:25 PM
rich152's Avatar
do you not have pressure at the gauge or no pressure at all. if the gauge is all you are using to check then try a mechanical gauge and go from there.
