can you adjust the idle on a 94 camaro lt1
Old Feb 22, 2008 | 03:47 PM
apyah's Avatar
or is it in the program, thank you ahead of time, Allen
Old Feb 22, 2008 | 03:58 PM
ss.slp.ls1's Avatar
I'm not sure but I think one of the sensors in the TB has an adjustment screw, either the IAC or the TPS. Why do you ask? If everything is in good working order, there should be no need to adjust anything, the computer does it for you. In the case that you are having a rough idle, you need to find the problem, not adjust around it.
Old Feb 22, 2008 | 04:14 PM
Bluovlh8er's Avatar
i kinda want to know too. on my 95m it runs perfict but idels at like 6-700
Old Feb 22, 2008 | 04:19 PM
Idle speed is controlled by the computer. The throttle blade stop is mechanically adjustable, but it is not in control of idle speed.
Old Feb 22, 2008 | 04:21 PM
11secgen's Avatar
i wouldnt mess with the screw. i think its more for taking the slack out of the throttle cable or somthing, but target idel rpm can be set with in the computer,as ''target idle rpm''i think freescan can also re set target idle.its done with a idle air controle valve and not the blades on the throttle body.i could see the screw causing a lean tip in condition.
oops! shoebox and myself answerd the question at the same time!
Old Feb 22, 2008 | 04:45 PM
apyah's Avatar
the wife thinks her 94 z28 idles to high, I have to look further into it.
Old Feb 22, 2008 | 04:47 PM
Check for vacuum leaks.
Old Feb 22, 2008 | 04:52 PM
94zgreenmachine's Avatar
what does the tach read? My step kid smacked up her car( says she hit a snow bank) but said she didn't think it was too bad. I drove her car and can negotiate thru a curve to the left without turning the wheel.Not bad
Old Feb 22, 2008 | 04:55 PM
Bow94z's Avatar
check the throttle cable on the TB, mine was stickin before keeping the idle at like 1200-1300
Old Feb 22, 2008 | 04:56 PM
AHARTZ28's Avatar
also check it with some sort of scanner the stock tach is not accurate.
Old Feb 22, 2008 | 07:12 PM
apyah's Avatar
I checked it and it is identical on both the 94 and 96 starts at 1000 and after warm up it goes to about 800 or 900 which sounds fine to me. Allen
SpeedJunkee
Jan 27, 2015 10:02 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
F(ast)-body
Feb 26, 2003 09:05 AM
slothgrant
Aug 22, 2002 03:01 PM
