can you adjust the idle on a 94 camaro lt1
I'm not sure but I think one of the sensors in the TB has an adjustment screw, either the IAC or the TPS. Why do you ask? If everything is in good working order, there should be no need to adjust anything, the computer does it for you. In the case that you are having a rough idle, you need to find the problem, not adjust around it.
i wouldnt mess with the screw. i think its more for taking the slack out of the throttle cable or somthing, but target idel rpm can be set with in the computer,as ''target idle rpm''i think freescan can also re set target idle.its done with a idle air controle valve and not the blades on the throttle body.i could see the screw causing a lean tip in condition.
oops! shoebox and myself answerd the question at the same time!
F(ast)-body
Feb 26, 2003 09:05 AM
slothgrant
Aug 22, 2002 03:01 PM
