can a speed sensor be tested?
Old Apr 28, 2004 | 05:22 PM
LT1 PWRD's Avatar
When your speedo won't work, it's either a speed sensor problem, faulty cluster or simply a wiring problem right?
But can a speed sensor be tested with a multimeter for voltage output while simulating driving with the wheels off the ground?
Just trying to eliminate some possibilties.
Thanks for the insight.
Old Apr 28, 2004 | 05:59 PM
HBHRacing's Avatar
i know in a chyrsler you can unplug it and use a jumper wire and rapidly plug and unplug the jumper simulating the voltage wave and watch the speedo for movement.
But I would asume that yes you could read outgoing voltage if your meter can keep up with the drops. lemme look over a diagram and see if I can be more specific
jj_burchiel
Mar 21, 2015 12:51 AM
naaz90
Jul 27, 2002 08:22 AM
