Can someone verify the Injector settings for me
I have a set of 30# SVO's and I want to verify what the rating is for my car. It is the last thing I have to do to finish off my tune. Anyone?
Q
Q
I believe the injector constant is supposed to be around 31 but like most people I had to adjust it some after I scanned the car so I ended up with 33 in the end.
Then you have the injector offsets to deal with. Below is what I have in tunercat... LT1 edit will need different values.
381.5
351.0
305.2
274.7
244.1
213.6
198.4
167.8
152.6
137.3
122.1
106.8
106.8
91.6
76.3
76.3
61.0
61.0
61.0
45.8
45.8
45.8
45.8
30.5
30.5
381.5
351.0
305.2
274.7
244.1
213.6
198.4
167.8
152.6
137.3
122.1
106.8
106.8
91.6
76.3
76.3
61.0
61.0
61.0
45.8
45.8
45.8
45.8
30.5
30.5
Hey Q,
If you calculate 30 * sqrt(44/39) you get 31.86 for fuel pressure at 44. If pressure is right on 43.5 then you get 31.68 so somewhere in between is probably good.
I would not mess with anything but the injector constant.
I'm telling you guys that messing with the injector offsets by voltage does no noticeable good. I know this from extensive personal experience. Only change the constant. Stock regulator is supposed to be set to 43.5 so 31.7 for the injector constant is a close match. If you want to lean the mixture for cruising then you can play with going higher at your own risk. On the other hand if pressure is higher then the contant needs to be raised.
Originally posted by dreamer1q
Thanks Brad, you are my hero
I really cant say much about those injector offsets. Originally I had them set as stock and after noticing a hesitation off idle I decided to go ahead and find some offsets for those SVOs. Truth be told... they didnt help at all. If I had the time and money to have all those injectors match flowed then I would have b/c it seems like the redtop SVOs arent that consistent from all the personal accounts from other board members.
