Can someone identify this vaccum line?
There's two vaccum nipples on the passenger side of the intake. I think the upper nipple is for the vaccum line that comes out the wiring harness. But the lower nipple, where does it connect to? I'm thinking it connects to a little solenoid looking thing near the EGR vavle. It is on a bracket adjacent to where the fuel lines intersect the fuel rail. I see a nipple on that "thing" and I figure a vaccum line runs between the lower intake nipple and that one.
I took the intake off to reseal it and this vaccum line is just... gone. And my memory isn't serving me correctly. Can somebody verify this?
Re: Can someone identify this vaccum line?
The lower nipple is the connection for the vacuum line for the fuel pressure regulator , and likewise the "thing" you're referring to is the fuel pressure regulator itself. You're correct in that this lower intake nipple does connect to that device.
