Can Someone give me the final answer for gas
Old Jan 31, 2007 | 08:15 PM
  #16
CALL911's Avatar
I'm with Bubba and Rich. Put the good stuff in. (premium)
Old Jan 31, 2007 | 08:59 PM
  #17
Mortify's Avatar
I say use premium, when I first recieved my car I used 87 because I didnt know any better... now switching to 91 and I do notice better fuel economy..
Old Jan 31, 2007 | 09:38 PM
  #18
Ellis's Avatar
I have in the past put 89 in my formy during the winter (in FL, that means under 80°F ). That was during weeeks I expected no action. Since I do 60 mi. a day on I-95 I burn through tanks pretty quick. Never had an issue, aside from the car being a bit lazy.
Always run 93 when weather's warm or if you are foot-happy.
Old Jan 31, 2007 | 09:39 PM
  #19
1FstFormulaV8's Avatar
I use 93. Which if I'm not mistaken the manual says to only use premium fuel. There's also a small sticker on the backside of the fuel door that reads "Premium Unleaded Fuel Recommened". Pretty much says it.
Old Jan 31, 2007 | 10:43 PM
  #20
Every manual I've looked at indicates exactly what "liltxboi911" quoted in his post in page 1 of this thread..... use 91 or higher, you can use lower octane, but performance may be reduced.
And as noted in another post, the specific octane requirement varies with altitude and with intake air temperature. You may not need the same octane in the cooler winter months, and you definitely don't need 93 octane if you live in Denver.
For max performance, follow the manual. If you have a scanner, check for knock retard when running low octane fuel. If you have knock retard, you are giving up HP.
C6LS3
Apr 15, 2015 09:50 AM
DetroitZ28
Feb 13, 2015 07:33 AM
ksharr
Aug 30, 2002 10:58 AM
madman69
Aug 18, 2002 03:58 PM
simple
Aug 11, 2002 11:56 AM
