Can someone figure my compression for me?
Old Jul 2, 2006 | 10:44 AM
mattbailey's Avatar
I'm builging a 355 with -5cc pistons, the block has been zero decked, I'm using felpro .039 head gaskets, and the heads cc'd at 48. I'm using a Joe O cam simular to the GM 847. I know it's going to be pretty high, but I can't figure it out. Thanks
Old Jul 2, 2006 | 11:22 AM
89TramsAmGTA's Avatar
Re: Can someone figure my compression for me?
Here is the static compression. I came up with 12.84 if those are flat top pistons with the 5cc valve reliefs. If they are slightly domed then I came up with 15.15. I used 4.090 for the inside diameter of the head gasket. It won't change things much if I'm off a little. Are you sure about the 48cc head volume?
Old Jul 2, 2006 | 12:43 PM
mattbailey's Avatar
I had a local machine shop cc the heads, I don't know what method they used but he told me they were 48 cc, I thought that was a little low myself. Is it possible for an LT1 head to have that low of a cc in the combustion chamber? The heads came off os Saintx's 383 that came from nitro Dave. They were ported by MTI.
Old Jul 2, 2006 | 04:25 PM
matLT1's Avatar
If you had a 58 cc head, which I believe is the original volume that would put you at a more realistic compression of 11.2. It is possible that they F---ed up ccing the head.
68camaroboltz
Oct 5, 2015 01:46 PM
surreybrad
Sep 29, 2015 09:00 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
NewsBot
Sep 14, 2015 02:02 AM
Daluchman1974
Sep 11, 2015 06:12 AM
