Can the screw for the oil dipstick hose bracket leak oil?
Not unless it's broken away from the dipstick tube, even then it would have a hard time to leak alot. If you've replaced the disptick tube, it may be that there is too much play in the bottom of the tube that goes into the block if you have sanded it or clearanced it in any way.
-Shannon
-Shannon
Darth Xed
13
Jul 22, 2002 12:45 PM
BAD00T/A
Jul 21, 2002 07:35 PM
