Can oil pressure be too high
Old Feb 18, 2007 | 06:34 PM
ZL1modified's Avatar
as asked above, can it?
through out the rpm range my pressure has been reading 70-75...
is this ok?
Old Feb 18, 2007 | 06:44 PM
JP95ZM6's Avatar
It ok for high RPM, but not normal for idle! Does the gage ever move? If not it sounds to me like it's running on the internal bypass spring all the time, which indicates a restricion somewhere downstream of the pump.
I'd start with a new filter.
Old Feb 18, 2007 | 06:53 PM
i just replaced all the gaskets and changed the oil and filter...
i also installed a new sending unit...
the guage does move...
i noticed the high pressure right after i adjusted my rocker arms...
before i messed with the engine the pressure would be between 40-60...
Old Feb 18, 2007 | 06:55 PM
mdacton's Avatar
mine was never below 40-50 with the stock pump
Old Feb 18, 2007 | 07:21 PM
Z-RATED94's Avatar
Even at idle, when up to operating temp?
Old Feb 18, 2007 | 07:23 PM
mdacton's Avatar
Yes. I always ran the same oil in it since new...castrol GTX
always was 40 at idle and the gauge was pegged at 7K
Old Feb 18, 2007 | 07:37 PM
i have a new filter...
could my valve lash be over adjusted?
Old Feb 18, 2007 | 08:55 PM
Originally Posted by roguedriver
Yup, you got problems broh. Drain your oil. I'd guess it's gonna look like a gold rush. I remember when my oil pressure looked like that. Now it looks like an engine sitting in a crate that my new 383 came out of....
Ken R.
whats your pressure...
i thought i started this thread... i don't mind helping another lt1 owner out but, come on... at least tell me if i'll be ok...
Old Feb 18, 2007 | 09:06 PM
Z-RATED94's Avatar
is this ok?
Has it always been that way? Do any thing latley to the car that might have a bearing on this? Have you tryed to hook up another gauge to confirm this high reading?
Old Feb 18, 2007 | 11:25 PM
Highjack by "tnmotown" deleted.
Old Feb 19, 2007 | 10:15 AM
What filter are you using?
You did not answer this question:
Old Feb 19, 2007 | 10:18 AM
i'll have to get it up to temp tonite and see... (running out of fuel)
i use fram tough guard
Old Feb 19, 2007 | 10:33 AM
mdacton's Avatar
I have used a few different types of filters if the Delco's are out of stock
But I think most of them have a bypass
Old Feb 19, 2007 | 11:22 AM
that question was not directed towards me...
Old Feb 19, 2007 | 11:45 AM
mdacton's Avatar
no I think it was....some filter work differently, could be a problem with it, I think thats why he asked what type it was
