Can an LT1 motor and 4L60-E be removed together?
Old Apr 3, 2004 | 02:18 AM
texasTA's Avatar
I am about to be removing an LT1 engine out of two cars. My question is can a stock LT1 engine be removed with the a4 tranny still attached?
I know this is doable with the m6, but I was under the impression that the a4 is a little larger than the m6.
Old Apr 3, 2004 | 02:44 AM
DarkRider's Avatar
I have never tried but I am sure it is possible. I always pull them separate .
Are you swapping the motor & tranny out of one and into another or what?
Old Apr 3, 2004 | 02:53 AM
93formula's Avatar
they can be if you drop it our of the bottom and reinstall em from the bottom. its very easy.
Old Apr 3, 2004 | 03:26 AM
texasTA's Avatar
So you would say that taking out the bottom is easier than out the top?
Yeah, I am taking my little brother's heads/cam/full valvetrain/race built tranny/stall and putting it in my car. And we are taking my stock motor/stock tranny/stall and putting it in his car. Both are LT1/a4 combos.
Old Apr 3, 2004 | 07:40 AM
dreamer1q's Avatar
http://www.michiganspeed.com/enginepull/index.html
Yes
Old Apr 3, 2004 | 08:05 AM
texasTA's Avatar
If you ever come to Texas I am buying you a case of cold ones. Taking the Beotch through the bottom doesn't look too bad at all. I just need to find some of those carts. Thank you so much.
Old Apr 3, 2004 | 10:48 AM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Yes
This looks to be the easiest way of doing it. I've had mine out the top four times, and being it's out right now I will me putting it back in this way. Good thing is I already have a cart just like the one you use. What was I thinking this whole time??? Thanks
Neal
Old Apr 3, 2004 | 03:59 PM
RicocheT's Avatar
it'll come out through the top together. I've done it a few times. You just have to get the angle right on the motor and the car. Make sure you have 2 jacks. 1 to let the front end up and down. one for the tailshaft on the trans. Of course you'll wanna leave your rear up on jackstands too.
I think after everything was unhooked (and i learned how to do it) it took me about an hour to start sliding it out this way.
Old Apr 3, 2004 | 04:31 PM
93formula's Avatar
the bottom is the easiest for this application, he can leave everything on the motor right down to the accesories and manifolds/headers. good luck!!!
willismoons
Feb 14, 2015 08:42 PM
formula218
Dec 2, 2014 04:27 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
centric
Aug 15, 2002 09:04 PM
