Can JB Weld seal a hole the size of a pinhead on my A/C line???
Old 04-04-2003, 08:13 PM
96 WS6's Avatar
I accidently made a very small hole in the A/C line. It lost all the pressure, can I put JB weld to seal the hole?
96 WS6 is offline
Old 04-04-2003, 08:16 PM
NOMAD's Avatar
Cool
My only question would be as to how long it would hold under the pressure. Other that that it would seem fine
-Shannon
NOMAD is offline
Old 04-04-2003, 08:19 PM
BigDaddy's Avatar
It should work fine. I don't think there's alot of pressure in the AC system anyway.
BigDaddy is offline
Old 04-04-2003, 08:57 PM
Mr Freeze's Avatar
i'd estimate a couple hundred PSI...what made the pinhole?
travis
Mr Freeze is offline
Old 04-04-2003, 09:07 PM
1FASASZ's Avatar
you should take it to a exhaust shop and have them tig a little weld on it that should be pretty cheap to
1FASASZ is offline
Old 04-04-2003, 09:17 PM
Mr Freeze's Avatar
i'm not sure you want to put extreme heat near any a/c system, even if you think the refrigerant is gone. i'm betting that the welder would weld your a/c right after your gas tank.
Old 04-04-2003, 09:23 PM
magius231's Avatar
I'm not sure anything can be done but replace that part...I seriously doubt JB Weld is going to hold under that pressure and temperature variation.
magius231 is offline
Old 04-06-2003, 05:11 AM
scoobysnax83's Avatar
my stepfather did the same thing to my mother 95 olds cutlass SL, the JB weld lasted about two days and they were out the money for the recharge. They ended up buying the part to replace. I guess it mostly matters wheither it is on the high pressure or low pressure side, hers happened to be on the high side. Good luck!
scoobysnax83 is offline
Old 04-06-2003, 05:39 AM
96 WS6's Avatar
Dammit I don't wanna replace that... What about RTV, then JB Weld, then a piece of rubber hosing with a clamp around it real tight? Would that hold the pressure??? I know this stupid little hole is not going to make me replace the whole thing.
96 WS6 is offline
Old 04-06-2003, 05:55 AM
joeSS97's Avatar
I am sorry to say that it will.
joeSS97 is offline
Old 04-06-2003, 06:27 AM
bowtiepwr's Avatar
>Stop being cheap and fix it right !
All I can say is if you nickle and dime this it will get more expensive later down the road .
examples :
1) you temp fix the hose , but it continues to leak ... you have to continue to refill the R134 and oil , and not to mention that you will have to clean the mess (if any) .
2) you refuse to use the A/C and let it "ride" for a while without any refriderant and the A/C compressor dies from no lubrication ( big $$$) while you sweat like a pig in Cali sun .
3) you remove the A/C and get a 1LE A/C delete bracket ... (big $$$) .
all I can say is bite the bullet , and buy the correct hose (AutoZone , Advanced Auto , www.gmpartsdirect.com , GM dealer)
bowtiepwr is offline
Old 04-06-2003, 03:56 PM
96 WS6's Avatar
It's been like that for a few months now... I don't drive it that much. So now my A/C compressor could be bad... that's friggin ridiculous, and i'm not cheap but you can't blame me for trying to find a cheap way to fix it. If it really calls for it I will replace the part.
96 WS6 is offline
Old 04-06-2003, 11:04 PM
you have got to be kidding, I think that that has topped the list for the most cheaply rigged project ever. I can't believe that didn't break.
Old 04-07-2003, 08:08 AM
IDOXLR8's Avatar
Which AC line are you talking about?? Let me know because I just pulled my AC off my car and will sell you the hose.
IDOXLR8 is offline
Old 04-07-2003, 08:46 AM
Gripenfelter's Avatar
Tried JB weld on my AC line last year. Blew off within the week.
Looking for a new condensor tube now.
Gripenfelter is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
QuickSilver02
04-07-2015 11:12 AM
Jason Short
01-19-2015 06:34 PM
squarehead
11-21-2014 08:02 PM
Quick Reply: Can JB Weld seal a hole the size of a pinhead on my A/C line???
