Can the intake manifold leak air?
Old Oct 17, 2003 | 08:16 PM
WhiteBeast's Avatar
Ok, There is a loud hissing sound coming from the front of the intake manifold. It is coming from the area where the little bar connects the 2 fuel rails.
I cannont find a leak anywhere. Could this possibly be my Throttle body?
Old Oct 17, 2003 | 08:34 PM
i387's Avatar
It's common for the rubber intake elbow to crack after a number of years. You might want to check that first, just unfasten it from the throttle body and look at the bottom side of it.
The bar that holds the two fuel rails together actually has fuel running through it.
You might want to check some of the vacuum connections on both sides of the manifold. There are quite a few in that vicinity.
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
