Can I use V6 springs on the front?
Old Feb 15, 2005 | 10:32 AM
Huntr1117's Avatar
If I put V6 springs on the front of my T/A will it drop it? I assume it will because of the heavier engine. Just wondering if this will even work, or if anyone has done this before?
Old Feb 15, 2005 | 03:26 PM
Huntr1117's Avatar
Re: Can I use V6 springs on the front?
ttt
Old Feb 15, 2005 | 04:11 PM
TraceZ's Avatar
I used to have a problem with a 3rd gen I had with V6 springs in the front. I suspect, but cannot cay for sure that you would have the same problem with a 4th gen car. It was mushy and bottomed out all the time. Even little dips in the road would cause it to hit. I ended up puting in V8 springs to correct the problem.
If you are going to replace the front springs, I would recommend getting something stiffer than the V6 springs so it doesn't bottom out so easy.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
KYWes
Apr 3, 2015 07:59 PM
ModdedNerd
Dec 25, 2014 05:51 PM
