Can I use Standerd Roller Rockers?
Old Sep 13, 2004 | 12:53 AM
lillbush5555's Avatar
I was wondering..If I dont have the supports in the center of my valve cover do I still need the narrow body rocker arms? Or can I use standerd RR?
Matt
Old Sep 13, 2004 | 04:41 AM
sssalah's Avatar
Re: Can I use Standerd Roller Rockers?
You don't have to remove the supports altogether, this will probably cause a leaking problem. I just trimmed one side of the support to fit the comp pro magnum rocker.
Old Sep 13, 2004 | 12:55 PM
Well they have been cut for a long time now..No leaks I just wanna know do I still need the narrow body rocker arms or can I use the standered ones?
Matt
Old Sep 13, 2004 | 01:03 PM
Spinner's Avatar
I've got standard 1.6 pro mags in mine with no issues
Old Sep 13, 2004 | 01:22 PM
what about crane? They not for use weith center bolt valve covers??? Why is that? do they cover the bolt holes?
Matt
Old Sep 13, 2004 | 03:25 PM
Spinner's Avatar
They all say that because they all hit the supports. They'll fit fine.
Old Sep 13, 2004 | 03:27 PM
Dave C. '97 Z28's Avatar
I'm running the standard wide crane roller rockers, along with guide plates, on my car with stock LT-1 heads and valve covers. My valve covers do have the center supports removed. No problems so far, but only 100 miles on the motor so far.
-Dave C. '97 Z28
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
