Can I use Standerd Roller Rockers?
I was wondering..If I dont have the supports in the center of my valve cover do I still need the narrow body rocker arms? Or can I use standerd RR?
Matt
Matt
Re: Can I use Standerd Roller Rockers?
You don't have to remove the supports altogether, this will probably cause a leaking problem. I just trimmed one side of the support to fit the comp pro magnum rocker.
Well they have been cut for a long time now..No leaks I just wanna know do I still need the narrow body rocker arms or can I use the standered ones?
Matt
Matt
I'm running the standard wide crane roller rockers, along with guide plates, on my car with stock LT-1 heads and valve covers. My valve covers do have the center supports removed. No problems so far, but only 100 miles on the motor so far.
-Dave C. '97 Z28
-Dave C. '97 Z28
