can I use a OBDII auto PCM in a manual car for test?
Old Jan 29, 2005 | 04:01 PM
Hawk's Avatar
I want to swap the PCM in my car to see if thats causing knock retard problems.
I have a manual 96 Z with ODBII. My friend has a spare OBDII pcm from a 96 trans am auto, it's stock programming. Can i throw this PCM in my car and will it allow me to drive the car around to just see if it cures my knock retard problem??
Brian
Old Jan 29, 2005 | 06:06 PM
hotrod18_69's Avatar
Re: can I use a OBDII auto PCM in a manual car for test?
I am not for sure, i know you will throw a TON of codes cause the PCM wont be able to find the auto..
Old Jan 29, 2005 | 08:40 PM
madwolf's Avatar
As it has already been mentioned, you will get a service engine light from a bunch of transmission related codes and you will be possibly locked out of a few gears, but you can try it. You won't hurt anything.
Old Jan 29, 2005 | 08:44 PM
Seal's Avatar
it might work, but i'm not sure if it'll shift out...
also ur speedo will be WAY OFF
Injuneer
Dec 15, 2014 09:36 AM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
naaz90
Jul 27, 2002 08:22 AM
